Hi, after about a week of research, I decided to write this post because there aren't many informations on this audio interface.
I decided to open my Mbox 2 and look inside it to find some possible modifications.
If anyone is interested and would like to make some suggestions it would be great.
I posted the internal pictures of the unit.
The AD converter are Cirrus Logic cs5361 KSZ and the DA is cs4392 KZZ.
Data transfer is cs8427.
The first thing I noticed is that the AD and Da can sample up to 192 Khz.. so why this limitation?
But, from what I have read in the web their are decent converter.
I think the worst part is the analog input and output stage.
The mic line pre's (and also the DI) are decoupled with Jamicon electrolytic capacitors (220 uf 100v, 47 uf 63 and 25 v), and they have a reputation of poor audio quality, and a small and cheap smd capacitors.
The opamp in the preamp stage is the jrc 2122 and ,I think, MAX4477.
In the DI section the only active part that I see is the K170 and one similar transistor but with 2 pins marked as AQ506R W6COO2A B0704.
The board is full of max 4477 opamps.
Near the output section I can see these max 4477 opamps no other.
It would be interesting bypassing the mic line and DI stage and go straight into the converter, but, for me, it is very difficult to trace the signal path.
An improvement that I would like to do is to change all the Jamicon capacitors with high quality ones.
Change the JRC 2122 mic line opamp with another one but I can't find one with the same specifications.
I've read that the MAX4477 is quite good as amplifier, but maybe it can be improved.
And the last mod I would like to do is to build a separate 5v for power the unit, instead of the one that comes from my laptop.
Could you help me by giving me your opinion?
Really thanks!!!
Pre amp Mic line stage
http://imageshack.us/photo/my-images/21/dsc7200g.jpg/
DI stage
http://imageshack.us/photo/my-images/203/dsc7193.jpg/
Converters
http://imageshack.us/photo/my-images/824/dsc7189.jpg/
Really thanks!!!
DI stage
Converters
