CJ
Re: Cloning 2503 Api transformer
« Reply #20 on: March 05, 2013, 06:53:08 PM »
i would twist 3,
that API circuit can drive a low z load pretty good so you do not need a ton of turns,
too much wire and your capacitance might go up too high,
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
joaquins
« Reply #21 on: March 05, 2013, 10:20:01 PM »
Thanks, it's a lot of wire to twist, I'll do it when came back to home, maybe a couple of month... Thanks for the tip!
If I don't know how it works, I prefer don't turn it on.
Graph
« Reply #22 on: March 07, 2013, 08:02:38 PM »
Thanks again Joaquins, i will be asking you by email later where did you get laminations for transformers so i can send them to clonate here.
12afael
« Reply #23 on: March 11, 2013, 12:20:08 AM »
you should try to contact to Cristian Tarufetti, Supermagoo here, he is the owner of http://www.vintageelectric.com.ar/ he know a lot about transformers and provably he know more places where to buy iron in argentina.
heavy metal is the law!!!
Graph
« Reply #24 on: March 26, 2013, 06:38:37 PM »
I know about them, but never contacted him.
Joaquins told me about where to get some, havent ordered some yet, since i am traveling next week and dont have much time :(
I will keep you informed if you are interesed, and with results i make :) if i can measure some DIY 2503 later.
CJ
« Reply #25 on: March 26, 2013, 08:17:22 PM »
be sure to reverse wind the xfmr as current flows in opposite direction south of the equator, right?  :o
Graph
« Reply #26 on: March 26, 2013, 08:57:33 PM »
I thought only water in toilets went in opposite directon :(
joaquins
« Reply #27 on: March 26, 2013, 11:52:18 PM »
No, here transformers ans screws are in opposite direction too!
JS
abbey road d enfer
« Reply #28 on: March 27, 2013, 01:32:25 AM »
JS
Not a problem because power sockets are reversed and screwdrivers are left-handed.
Last post June 23, 2004, 01:43:21 AM
by
Last post October 08, 2008, 08:00:31 AM
by raysolinski
Last post July 06, 2019, 04:36:08 AM
by abbey road d enfer
Last post June 17, 2019, 09:25:35 AM
by gyraf
