EmptyMusicBox1
Re: Channel Strip projet SSL 9K/W492/CLX-VU
« Reply #20 on: March 27, 2013, 02:34:44 PM »
On the Audio Way (preamp-->EQ--> comp) i need to Sym the audio signal to the output of each element ? ( between preamp EQ / EQ comp )
abbey road d enfer
« Reply #21 on: March 27, 2013, 03:28:21 PM »
No, you don't. Unless you want to provide access to all intermediate points. But even then, you could do it unbalanced. After all, that's how it's done in thousands of mixers, the insert points are unbalanced.
EmptyMusicBox1
« Reply #22 on: March 27, 2013, 03:49:14 PM »
Ok ! thanks abbey road d enfer
And i can for exemple Split the audio signal before the Sym for one direction to EQ (asym) and after the Sym to a Direct out  ?
abbey road d enfer
« Reply #23 on: March 27, 2013, 04:36:46 PM »
Yes.
EmptyMusicBox1
« Reply #24 on: March 27, 2013, 06:21:59 PM »
Great for the Audio question :) !!! thanks !!!
new interrogation ! On the PSU of the SSl 9k i can read that :
AC 18v plots of the trans Series or Parallèle ?
abbey road d enfer
« Reply #25 on: March 27, 2013, 06:35:37 PM »
The secondaries are in series.
EmptyMusicBox1
« Reply #26 on: March 27, 2013, 06:40:26 PM »
Oh no... with a trans 36v DC Series and 18V DC parallele not working  for this PSu ?
abbey road d enfer
« Reply #27 on: March 27, 2013, 06:50:33 PM »
I don't see any problem. Your xfmr is perfect for producing +/-18V rails.
EmptyMusicBox1
« Reply #28 on: March 27, 2013, 07:00:27 PM »
Oh ... i' sorry but don't i understand
my interogation is :
if the PCB need +18AC -18AC fo my Xfmr on Serie mode How i can wire that, with the VPT36-690 with a 36V AC on serie mode ?
(sorry but i'm a New DIY'er)
abbey road d enfer
« Reply #29 on: March 27, 2013, 07:15:31 PM »
The PCB doesn't need +/-18Vac, it doesn't exist. It needs 2x 18Vac.
See attached.
EmptyMusicBox1
« Reply #30 on: March 27, 2013, 07:23:18 PM »
oh yes ! thanks i have see my problem
for the SSL9k need that :
And the CLX need that :
it's not the same No ?
abbey road d enfer
« Reply #31 on: March 28, 2013, 03:00:28 AM »
It's the same. On the GSSL, the connection that links the two windings is done on the PCB. On the CLX, the connection is done outside. Same thing, two different ways.
EmptyMusicBox1
« Reply #32 on: April 18, 2013, 07:41:41 PM »
HI
New interogation about the Vu Led meter :
On the CLX PCB i can switch the Vu meter for the GR/INPUT and OUTPUT audio signal ! if i wire 1 Vu meter for Input/Output signal and other for the gain reduction it's Work ?
Because i want this info on the pannel as the original Meter of the DBX160A
thanks
EmptyMusicBox1
« Reply #33 on: April 28, 2013, 10:10:56 AM »
News !
I change my plan ! i remplace the W492 for a SSL 502  EQ i think it's better with the SSL preamp
i have juste read that :
502 pinouts are:
1a                     Master reset
15a/15c               Lamps
16a/16c              +18v
17a/17c/18a/18c     0v
19a/19c              -18v
20a/20c              -18v (-18V BU?)
21a/21c               -24v
22a/22c              -18v (LEDS)
28a                     Dynamics Pre EQ
29a                     ON
30a                    UNBAL out
32a                    UNBAL in
it's correct ?
abbey road d enfer
« Reply #34 on: April 28, 2013, 01:03:16 PM »
News !
I just wanted to tell you that it's a bad idea to use several PSU's from one single winding (even when it's a center-tapped winding).
You should use only one rectifier, one set of smoothing caps and distribute the DC rails.
In the former case, you create several "dirty ground nodes" that will be connected in the end, this is a receipe for introducing rectifier noise in the audio.
In the latter case, you can fefine only one ground, that you can manage to keep clean enough.
EmptyMusicBox1
« Reply #35 on: April 28, 2013, 01:16:13 PM »
oh okay ...
i need  AC voltage : +48v /+18v/ -18v/ +24v/-24v for SSL preamp& SL502 : http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=166
and ... +15v/-15v/ +24v/-24v for Clx
i need 2 Tx ?
abbey road d enfer
« Reply #36 on: April 28, 2013, 01:35:10 PM »
oh okay ...
i need 2 Tx ?
You could use one 2x20Vac xfmr. That would give 28Vdc that you could distribute to 3 sets of regulators at +/-24, +/-18 and +/-15.
Now these 2x20V xfmrs are becoming rare as hen's teeth and there would be a lot of heat wasted in the regulators.
I bet you don't really need +/-15 and +/-18. All these circuits should be capable of working with a single set of +/-18. The only limiting factor is the max specification for the opamps. 5532, 5534, TLO's are all capable of running on +/-18.
If I had to do it with standard components, I would use 2 xfmrs, one 2x24Vac and one 2x18Vac.
EmptyMusicBox1
« Reply #37 on: April 28, 2013, 02:33:37 PM »
oh okay ...
i need 2 Tx ?
i need also +48v for the Phantom ...
for 2XTX i don't the space for them... i think i can change the PSU for only +18v/-18v/ 48v stable with JLM audio and i use the PSU for the PCB(integrate)of the CLX only for the comp... the risk it to have audio Buzz on the ground ? maybe be i can Lift no ?
abbey road d enfer
« Reply #38 on: April 28, 2013, 05:13:13 PM »
This, you get from a voltage doubler.
Yes.
No.
Do you need a "noble" 24V? If the 24V is for an LED string, you can use the raw voltage from the rectifier.
EmptyMusicBox1
« Reply #39 on: April 29, 2013, 05:13:41 PM »
Thanks abbey road d enfer i continue the reflexion about !
Last post December 26, 2006, 11:48:53 PM
by pucho812
Last post May 07, 2008, 04:03:44 AM
by flight
Last post January 10, 2021, 02:08:28 AM
by BerndVP
Last post August 09, 2015, 05:43:18 PM
by e.fiocco
