rob_gould said:Any reason why this won't fit into 1RU if small meters are used Gustav?
Rob
Gustav said:rob_gould said:Any reason why this won't fit into 1RU if small meters are used Gustav?
Rob
I havent checked it, but no - no reason. The front panel board is not too tall for 1RU, so you should be able to mount it as is.
I was planning on building both a 1 and 2RU this month, when my pots for the kits arrived, but I currently have a suspicion they missed my order, and I will be waiting another 3 months
They have dual gang 4M7 pots at Reichelt, which will work with a little leg bending for the PCB.
Gustav.
G-Sun said:So, I guess drumbus and masterbus is not the typical application for the Symmetrical FET.
I just need to rethink my setup a little.
Gustav said:I feel the addition of a side chain high pass is a symptom of a problem using the gear in 99 out of 100 times
Ok, thanks!Gustav said:I feel the addition of a side chain high pass is a symptom of a problem using the gear in 99 out of 100 times, but opinions will vary on that.
I think these kinds of questions would be better suited for "Studio A"!?
Deepdark said:I think you could give it a try
G-Sun said:Is it a problem modding it according to...
Thanks for the tips!Gustav said:You could compare the schematics as a start (at least the part you have to the 1178)
Also, I generally recommend that people build something, make sure they have it working as intended and make observations (with their ears) about the stock circuit before doing modifications.
