I'm not an engineer, so perhaps I don't see what you see, but it doesn't look too entirely complicated other than the two proprietary IC's
, the first of which could be a "High Dynamic Range MMIC Mixer" while the other seems like a Texas Instruments Op Amp (though if only I knew how to read the values to figure out which one haha). which is probably what you are talking about. Those would definitely need some investigation. Pictures of TLM 193 internals can be found in this other thread:
Neumann TLM193 circuit help?. Everything else looks pretty standard, though. I actually wondered how the older style KM circuit (e.g. from KM84) compares to the newer KM 100 circuit above (e.g. KM 184), and whether or not the older circuit could act as a replacement for the new one and what effect that would have (especially given the transformer)? Kits for the KM84 circuit are readily available.
From the TLM 193 product description: "This unit is mated to the proven FET 100 circuitry of the KM 100 series."
Looks like 49.9K
Of particular interest to
@kingkorg and
@soliloqueen, perhaps by divine providence, I've already sourced an older TLM 193 in rather "ugly" cosmetic condition with a connection/grounding issue that seems easily resolved. It's likely related to the beat up XLR connection tube (it's missing a piece of the tube..something I've seen before elsewhere). Works and sounds great if the mic is held on it's side or upside down according to the seller (who has an excellent rating and was quite thorough in their description). At half price, I figured it was worth the risk, and worth it just for the capsule, head basket, and body alone, even
if it needs a new chassis bottom (fingers crossed it's removable from the rest of the chassis) and/or circuit. Won't be able to work on it for quite some time, but I'll report back with pictures and a summary when all is said and done..assuming I won't be coming this way with problems haha. But, it really just looks like the mic
maybe needs a new chassis bottom if there is any issue with the cable (working that out with the seller right now). Otherwise, a good cleaning, tightening some screws, and maybe a touch of solder somewhere should do the trick. Fingers crossed!
Would be nice to work out the circuit in the meantime out of curiosity and future reference in case of repair need and/or enough interest eventually arises in a
@soliloqueen K89 capsule
