ForthMonkey
It's standart and mastering eq based Neumann OEV.
There are some differences between OVE-RQ and original unit.
-Single mid band separeted to two mid bands.
-No inductor for mids.
-Elec. balanced in&out.
I finished first unit and working well!Now time to racking.I used potentiometers as standard edition.You can build it as stepped gain.I will add resistors values,bom and schematic...
Now i have 8 boards to sale.Check Black Market.
WORK
Loaded all components.And time to add switches.It's low freq switch.I decided to use pinheader for connections but soldering pins are really hard!And i found better idea!I soldered wire and now those are solid as pin!So i can directly put wire to sockets.
HPF:OFF-30-50-80 Hz
LPF:OFF-10-15-18 kHz
Low Band:40-80-100 Hz
Low Mid Band:125-250-500-700-1000 Hz
High Mid Band:1400-2000-2800-4000-5600 Hz
High Band:7-10-14 kHz
WORK
![p96ALo.jpg](https://proxy.imagearchive.com/f23/f235d08742f0cd077ccd117d6512b1bf.jpg)
![kJOQlJ.jpg](https://proxy.imagearchive.com/db9/db93412d0ae24cf28eb03398615996fa.jpg)
![68mWdk.jpg](https://proxy.imagearchive.com/0e0/0e004d193ef78d07a506e2a856ddcc71.jpg)
![OBZj4D.jpg](https://proxy.imagearchive.com/3a0/3a0ceeca247279b4812ea3a85d52679a.jpg)
![11894027_1033061940051761_6541193415127263340_o.jpg](https://proxy.imagearchive.com/8e6/8e64689d4982523d09307981a87ebd12.jpg)
HPF:OFF-30-50-80 Hz
