jimkeaney
Hi Guys,
A couple newbie questions if you'd be so kind? ...I'm trying to measure the current drawn from a Quad Eight EQ module (I'm racking 4 of them, and trying to find out if this Fivefish PSU will be adequate for all 4). The EQ's are +18/-18. I put my DMM inline on the + between the PSU and the EQ. It reads 65mA. So is that the total draw or should I also be measuring - or ground too and then do some sort of equation?
Bonus questions...
1) Should I be passing signal through the unit while measuring? Like if I turn all the knobs up(boost), does that make the unit work harder?
2) The Fivefish PSU pcb has 4 sets of (+/-/ground) solder pads. Should I wire each EQ unit to each of those or should the units be daisy-chained? I thought I read somewhere that if units are powered in parallel, the voltage would be divided to each unit, so they should be wired in series. Any clarification?
Thanks in advance for any knowledge you'll share...
Bonus questions...
