As this "vintage" console had been sitting in my stuffed workshop for a while, I thought this would be a good time to start a new project. I acquired the stinger in a trade for some awesome 500 series mic pré-amps I built. It smelled of cheap cigarettes and beer when it entered my house. And surely after a few days I regretted swapping my OV560's for this murky scorpion! But, when I fired it up it worked! I swiftly went through the console and found some scratchy pots and faders, a blown LED and some missing knobs, but overall it looked in good shape. So I gave it a quick scrub and lifted some of the channels en for what I could tell it seemed not to have been worked on all that much, so I put it away for a time like this!
I've been researching a bit about a possible revival of this little console, and I found a great deal of information about it on the old analog console forum and some other forum, something with sluts? But I believe it might be a good dead to get it in proper working order before I start messing around with it. So I stripped her down to her bare bones, and made a list of things that her previous owner put her through, starting at channel one onto 32 and on to the auxiliaries, sub-groups, and finally the master section. I had a small stroke after reviewing the list of stuff that had been done to this console, besides the relentless second hand smoke abuse!
But onward we go, and today we cleaned her out, gave the old girl a sponge bath, and really dug in th.... wait, this is starting to sound like a grannies **** movie!! Let's get to the facts.
We'll start with recapping the S4000 master section, well I find it hard to call it that as it's no bigger then a single channel strip, but the master section it is! The S4000 we've got seems to be worked on, and at that I believe it was done by someone who could read, but not interpret a plan as the coupling caps of 100uF 10v caps were replaced with 10uF caps right in front of the insert point! and the same happened right in front of the main outputs, but with 47uF caps. Now I could be stupid, but the only reason I could think of these would have been replaced by smaller then original parts could maybe be because they installed sowter 3612 transformers to balance the outputs. But I thought that the output impedance was 180 Ohms, which would be no problem for the 600 Ohms a Sowter 3612 carries on the input!? So to give you an idea of what was done to this master section, a list:
- C27, C28, C29, C30, C33, C34, C58 and C59 were replaced with wrong size caps, some of which I get.
- U11 and U12 , behind the fader were replaced with different brand TL072's .
- R75, R76 and R77 have ben cut from the circuit, effectively cutting auxiliaries 2,3 and 4 away from the talkback output!
- All ribbon connectors have been replaced with other connectors, so the don't fit right!!
- At least three traces or pads have been cut by de-soldering.
Anyway I think it would be best to revert this one to original to start with! I'll be replacing the caps with those little red ones Colin at Audio Maintenance sells. So he received an order for the following caps, together with 4 replacement pre-amp kits for the S1000 input channel., and within a few hours I got the message the were already on their way!
As I progress through reviving my little scorpion I wouldn't mind everyone's input, I'm sure a few of you have done this before and maybe some of you will do so after reading the end result of this trip.
A quick measurement taken through the masters insert return channels of the left and right mix-buss. And the result: +/- 0.5dB from 20Hz to 20kHz. And the fase was inverted because of the inverting fader booster amp.
