EDITED SEP/2020
It seems that the transformer used might be an UTC A-10 and not an UTC A-20,
please read post in next thread@Whoops
now that I've made your day, do you have any suggestions or thoughts on my switch problem?
@Whoops
Also, this box was originally created using a Triad A11J transformer
I asked what transformer you were using to try to help you out, as you were not clear at all in your intentions in the first post, others pointed that out also. But there's nothing here to make my day, I went to the beach today and that made my day.
Also the favorable DI at Motown as per Bob Olhson source (Motown Mastering Engineer) was an UTC A20 transformer connected backwards, Bob says that in a couple of threads on the internet, he also told me about that when I met him in Nashville in 2012.
Not to say that they didnt have other DI devices at the studio, they probably had, like the Mr. Ed Wolfrum DI device.
I just pointed that out because the title says "Motown DI"
As for helping you out,
sure. But I can't add more to what other people already said.
As shabtek posted, you need a DPDT switch (double pole double throw), thats what you were referring for a "6 lug switch",
So my suggestion is to buy one DPDT switch, wire it as in the schematic (B2 is the center of the switch) A and C are the sides, doesn't matter which side you use for C or A, just choose one for A do the A connections there and use the other side for C.
Do you have a Digital Multimeter (DMM) to use measuring continuity and resistance?
As for the volume problem, could you explain it better what you are experiencing?
The volume Pot is part of a variable attenuater circuit at the input, before the signal hits the transformer primaries, using the pot will bring the volume down. The DPDT switch is there to insert the attenuation in the circuit or bypassing it.
With Electric and Bass guitars equiped with passive pickups you will not probably need any attenuation, but with hot signals from some keyboards, instrument active circuits, drum machines , etc it might be really useful .
