Mbira
Here's the story. A group that I play with uses zimbabwean style marimbas. These are nothing like their western counterparts as the keys are very thick and yield very minimal sustain. Also, the resonators (pvc pipe) generally have a 1" diameter hole at the bottom with plastic covering the hole to give a "buzzing" sound when struck.
The group uses four marimbas on stage as well as drum-set, electric mbira, and four vocals. The bass marimba is 7 feet high and keys are around 12" wide, 2" thick and up to 2.5' long.
We have been miking the bass marimbas. I am generally happy with that, but that ends up having over 16 open mics on stage often, and we play on very small stages (for us). I still think the mic trick is the best solution, but the other guy in the band (the one who builds the marimbas) is constantly searching for ways to complicate-I mean improve things. He has installed peizo pickups in each individual bass key (in the nodes) and then wants to wire them all up and plug the bass marimba straight into the board.
Do you guys have any thoughts on how best to do this? I have found peizo's inconsistant at best and the gain of one seems much greater that the gain of another. I was thinking of maybe trying to wire each one in parallel and running into a summing box where we check the impedence of each peizo and put in a resistor for each to get a level signal and then run out of the box into the board.
As a person who likes simplicity though, I still feel like a couple of mics may be a better solution.
Any thoughts?
Joel
Any thoughts?
Joel
