CJ
just a short blurb on the Sunn Beta Bass and Beta Lead amps,
got a few in with the same problem, TIP29 and TIP30 driver pairs,
they get hot, the glue ages, the undersized clip-on heat sink falls off, the transistors get hotter, collector trace pads start to cook,
rest of the amp is very dependable, so just fix the driver problem and you are set for a life,
why do people play these old relics?
it's that ch1 - ch2 mix thing, plug into the middle input, set one up for treble crunch, the other for clean, mix em up and it's like instant Lemmy from one amp, you beta freaks know what i'm talkin bout,
anyhoot, here is what we do down at the shop, grab a 2 x 4, cut it down to 2 x 5
cut up an old reverb pan and no need for insl kits as you are isolated, we even used wood screws for the transistors,
this is overkill as the drivers don't get That hot, but the amps never come back which is a good thing in a small town, where people remember the bad and forget the good,
there is a bar next door and i can hear em thru the wall, ;D
