10KHZ Ground Noise in Studio
Whoops
GDIY Supporter
Portugal
I'm working at a studio at the moment were there's a present 10khz (actually is somewhere between 9.5Khz and 10Khz) in the Audio signals.
That noise is more present in Keyboards, Guitar and bass amplifiers and any signal I connect to a DI.
It's also present at mic signals although lower in level.
In some keyboards I was able to completely clean the signal by isolating the ground at the power plug (ground lift on the DI didnt stop the noise).
For the sake of testing I also isolated the ground at the power plug on guitar amps although with no improvements at all.
The Studio is at an industrial location, and was made at a warehouse over the years, it was a properly planned and implemented project so the electrical installations is of a warehouse and not a professional studio.
The Console and all the outboard are powered  through Furman PL-8 C E Power Conditioner's, that are speced with having "Noise Filtration - LiFT offers AC power filtering to ensure clean power for unequaled audio & video clarity" and "Isolated Banks - Isolated outlet banks minimize inter-component interference and noise contamination".
Backline like the guitar and bass amps are powered in the live room and connected to the normal wall power plugs.
The 10KHZ noise seems to be worse in some days than the others,  although the frequency is constant.
I would like to minimize this problem as much as possible, knowing that the studio is not mine, so I can't do a new and well planned electrical installation.
What might me the cause of this problem?
What could I do to test and find the culprit/culprits?
Any tests you could advise?
What could I do to minimize it?
Thank you so much
The power conditioner will only stop noise getting in from the outside mains supply.  Sounds to me like you have something on the inside causing the interference. The most likely culprit is a switched mode power supply (SMPSU). Laptop power supplies can be culprits but any gear with a SMPSU in it can produce this sort of noise.
Monitor the noise, and switch off (unplug) everything connected to your power line one unit at a time until you find the noisy one.
If noise comes in with the mains voltage (from neighbor companies doing e.g. plasma cutting), talk to your electricity supplier - they'll know how to filter efficiently.
Jakob E.
A 10kHz noise could be coming directly from something switching @ 10kHz (or an unstable circuit oscillating), or indirectly as a beat frequency between two much higher frequency sources that aren't audible by themselves, but differ by the audible 10Khz.
Thank you all for the advices, I will try that.
I will see if there's a possibility of testing it, listening the noise while unplugging everything one by one.
I don't think is something that simple like a laptop PSU, or a small switching PSU adapter, because that noise is present all the time, even with no laptop connected, it seems is more structural in the building itself (like lightning installation) or it comes from outside the building and as it's an industrial old area.
Will see, thank you
If you have any more ideas please let me know
Will see, thank you
Unless the noise is in the last link of your audio chain.
Do you hear it in cans? Portable radio?  etc.... divide and conquer, troubleshooting 101.
Will see, thank you
I hear it when I record to protools DI signals, I hear it when I connect a guitar, bass or keyboard to an amplifier. I hear it from the guitar Amplifier even with no input jack connected, although much lower in volume, it's always there
thanks
Tinnitus?  (kidding)
No seriously maybe sniff around with a cheap AM portable radio.
Scope probe stuck in the air with a short piece of wire...
It's coming from somewhere, maybe everywhere.
Look up Power-Line Communication. Same sort of thing happened at a studio I worked at. 16kHz from every guitar amp, even a battery-powered toy.
JohnRoberts said:
Tinnitus?  (kidding)
Thanks John, will do that
I never done that before,  can you please elaborate on how to do that.
Do I connect the scope probe to the AM radio antenna?
10kHz is a bit low for AM Radio, but maybe your 10kHz is derived from higher frequency, so try if you can tune and find some carrier or harmonics of the 10kHz.  And maybe you can even track were it comes from by walking around with the radio.
Battery powered radio is your friend.
Back in the 80s we had a problem with a "glitch" coming in on the power lines.  We could actually see it on a scope.  Turned out it was a bad large power transformer on the rail system 3 blocks away.......  Found it with a tape machine repro head connected to a battery operated guitar amp.
Bruno2000
Whoops said:
JohnRoberts said:
Tinnitus?  (kidding)
I was talking about two different tests... sniffing for RF with a portable AM radio is one test, another is sticking a probe in the air with a short length of bare wire... scope probes are high impedance and high bandwidth so may see your noise, and where it is stronger.
JohnRoberts said:
Whoops said:
JohnRoberts said:
Tinnitus?  (kidding)
I have had a 10K problem for a while in a live situation that I deal with. We know what it is and it only is in the high gain vox mic channels so we gate it out. It comes from a pulse width modulated LED lighting dimmer that feeds LED tape. It is inductive into the mic cables that run near the ribbon cable that feeds the LED tape. That's all I got hope it helps!
If you had a laptop running a software spectrum analyser, like REW, then you could directly check for 10kHz signal from some of your 'sources' such as guitar amp or MIC.  With laptop not connected to anything, and showing a suitable noise floor, and then connected to a 'source', you could try and compare sources for their 10kHz levels (eg. devices not connected to anything but the laptop, compare to devices connected mains AC).  That may localise if signal is mains distribution related only.
Can you confirm there is no 10kHz when all inputs are disconnected, as well as connected but padded down.  That would localise to just connected devices.
The noise is on  guitar amps even when inputs are disconnected, it's much lower in level but its there, if a guitar is connected is  much louder
The same noise is on every DI input I record, Bass and keyboards
It's also present in microphone signals if I have to turn the gain high, imagine a dynamic mic capturing an acoustic guitar, or a dynamic mic used for Room it's there, with condensers the the mic signal is louder so no need to turn that gain up on the Mic Pre for the 10khz to be noticeable
I guess the issue is to confirm if the 10kHz signal is radiated in, or conducted in, to your analog sources  (eg. mic, guitar).  Some thoughts are:
The increase with guitar connected could be due to the guitar wiring having stray coupling to ground through a person, or from radiated pickup.
For example, if you could record the signal from a Mic in to a PC application running on a standalone device with no other electrical connections (eg.  iphone, or laptop), and could confirm that 10kHz was on the recording, then that indicates the signal is ingressing via radiation.  If the same action was done at another location, and there was no 10kHz, then that is good info.
Perhaps if you connect an unshielded lead to a DI, with a few meters of wiring to act as antenna, then observe whatever background signal the DI generates, and vary the orientation of the wiring, and when it is being handled.
