JohnRoberts said:
For summing a modest number of stems there is little need to pad the master bus... I only did it for one console that had over 100 feeds to the L/R bus.
Looking at it backwards, how many of the exact same signals, or even similar signals will be playing in the mix at full level at the same time? Answer should be not many. The existing 20 dB of bus headroom above 0VU should be adequate to prevent saturation in typical use.
Only a problem if you over think it into being one. 8)
I suppose that bus padding is hidden when considering that most inputs come from preamps with variable gain, so the original question, "on a mixer, if all faders and gain trims etc are set to 0 and you have a signal on the line input, should you expect the signal to be the same level at the master output?" is somewhat moot. You trim the inputs up to some level, perhaps 0 dB on a PFL meter, and then adjust faders to make a mix.
And this sort of plays into something I've always wondered about. Those of us who've mixed on large-format Midas consoles (like the H3000) "know" that you have to run the input levels "in the red" to get it to sound "right." And by "right" I don't mean that it sounds "better," I mean that there's something coming out of the rig!
I suppose this has to do with the choice of operating levels inside the console. The mix-guy hits the PFL button or otherwise watches the channel input level meter, and dials up a level as the musician makes a jazz noise. There is some level called 0 dB, and that's a reasonable target level. Lather, rinse, repeat for all inputs. Now on the big Midas, if you do this, you've got a quiet mix, and this is reflected not only on what comes out of the speakers, but also the output mix bus level meters. So to get anything happen, you have to crank the input levels until the meters turn christmas-tree red, easily +9 on the PFL. There's no distortion on either inputs or outputs, but the meters are screaming at you.
If the expectation is that you're really going to mix four dozen inputs to left/right and that those inputs are reasonably coherent (say, you're mixing an orchestra and you've got a dozen mics on the violins and violas), then it makes sense that you need to trim your inputs cold, that is to Midas' recommended 0 dB on the input meters, to prevent bus overload.
But for little vocals/guitars/bass/drums/percussion rock band I mix, which uses all of 24 inputs, and half are for percussion, I'm not going to overload the mix bus at all even with inputs trimmed to +9 dB on the H3000's input meters.
This is just a weirdness I've noticed from mixing on these things.
