First time poster, 3rd piece of CAPI gear (2-vVP28's - awesome) I just finished my first LC40 EQ. As far as the Grayhill switches go, if I happen to install 5 of them backwards (which I did) such that the stop pin is at the 6 o'clock position, would that cause the eq not to function properly? When I turn switch from bypass to on, and all rotary switches at 0 position, the db level drops slightly and bottom 4 knobs only change the sound when turned one click counter-clockwise. The 11 o'clock position causes an INCREASE in db for those bands. I think I really hosed this up. My plan is to use the desoldering vacuum at work and try to salvage the switches so I can install them correctly. I was just wondering if the lack of function is due to incorrect installation of the rotary switches, or if I need to look at other things as well.
Also, I may have exposed Q3 and Q5 on the DTO5 to too much heat as I swapped them accidentally and needed to solder wick them out. Not sure if this could also be the problem. Good times..
Thanks for any help
