Carnhill and pultec inductors, partially stuffed G7, and more.
Rocinante
Minnehopeless
Okay so stuff has been added and updated.
I am open to trade and currently i am looking for a bunch of transformers.
I need an EA-10468  or vtb 9046 and i would be interested in an EA mini-1166.
I'm also in need of a 1:10 mic input transformer or two (like jensen or Cinemag's cmmi-10c)
Please add anywhere from $3-$5 for shipping in the US or Canada. Everywhere else feel free to pm me after figuring out roughly the cost from Minneapolis 55407
Okay so here is a G7 and the psu pcb with some stuff attached.  Resistors are soldered on the mic board but the caps are not.  The yube is just an 12ax7 i used for measurements.  The psu is stuffed and ready to go.  You get some nice caps to pick from including evo and wima and if you would like the temporary frame you can have it but it is to short (my plan was to use another mxl v57 mic frame)
The capsule on it is bogus (like the tube) and was used for determining size.
I've probably got $40 in it.  So including shipping I will sell it for $35.  There's a 10 inch long 2 inch wide copper pipe that can go with it for an additional $7 for shipping withthe  copper pipe.
https://postimage.org/app.php
t
Carnhill 9048 inductor
G-Pultec inductor
6 x amphenol type 30 pin card edge connectors.  4 with solder tabs and 2 that are through hole. - $10
2 x used capi  card edge adaptor for 500 series-$5
I have a box of potentiometers, toggle, push button, and rotary switches that I've collected over the years. Some are new. Some are used.
Make an offer.
Potentiometers
4 x 10k log single gang alpha
4 x 20k log single gang something
4 x 25k lin
2 x 50k lin dual gang
5 x 5k lin single gang alpha
Switches:
4 x 1 pole 12 throw alpha switches (like lorlin) with diy tubes gain switch pcb
(2 x desoldered and 2 that make up a 470 ohm stepped log switch) .
2 x brand new 1 pole 12 throw alpha switches.
2 x 1 pole 12 throw pre wired alpha switches.
4 x 1 pole 12 throw used lorlin switches
2 x 2 pole 6 pos pre-wired lorlin
10  x dpdt (center off and off on) toggle
2 x 1 pole 10 throw mini grayhills
20 x wima caps - .001 to 1uf
Vintage and NOS capacitors and resistors that I bought from an old amp builder with the intention of doing some ptp builds a la LA2A and Pultec.  Make an offer.
Ceramic
Vintage and NOS Resistors:
Ohmite, allen bradly truohm etc...
Capacitors vintage and hi watt
Some are old and dirty some are NOS.
Black beauty, Jensen, sprague, dubliner, bumble bee, etc...
Kind of an amp builders box of goodies.
Will ad more stuff and more pics soon.
Dylan
and may the 4sbwitu
always
4 x card connectors sold. Still havee 6 left. No one needs a carnhill inductor or nice g-pultec inductor?
