F.S. Dale Vishay PBG 12205 Dual Plasma Bargraph Modules For Studer 980 Console
sahib
Glasgow - UK
Dale Vishay PBG 12205 Dual Plasma Bargraph modules.
These will work on Studer 980 console or the meter bridge for that console.  If you have one then I suggest to grab these as spares as they are now completely discontinued and very hard to find.
Fitted onto a PCB as a block of four,  each of which contains 8 meters. Three of them would make a 24 channel meter bridge.
The orange boxes on the left are the LEDs for back illuminating the scaling. The scaling is essentially a black film with clear legending and were originally stuck using a clear double sided tape. I will also include the films.
All the connections terminate at the colour coded ribbon cable and there are mounting stand-offs. So you do not have to tamper with anything.
Link to the designer's guide with application schematics.
http://ferretronix.com/tech/nixie/pdf/vishay_dale_bar_graph_designers_guide.pdf
GBP 150.00 each plus shipping and paypal.
I also have the high voltage power supply modules for these. One module can power one block of 8. If required these can be purchased separately.
They are.
Please PM me your address and the quantity and I'll work out the shipping cost.
I'm interested to buy your all  Dale Vishay PBG 12205 Dual Plasma Bargraph Modules For Studer 980 Console
Regard's
They are still available.
In fact better news, since then I have removed them from their boards as this was putting people off.
