here is the preamp circuit, mods were reducing gain by increasing the cap/resistor combo to 3 meg/100 pf, kind of like Fender but different, Fender uses 10 pf but this amp has a treble rich speaker and cabinet,
we changed stage 1 plate R from 220 to 100 K, and bias resistors as well, (circled)
also, the voltage divider (R36/R33) was not layed out right so the pc board has an error in it, so we had to cut and splice to fix that,
we took out the afterthought cap spliced across R34 which was a stabilizing mod and the waveform got a lot better, that cap was causing hideous distortion on one side of the wave, next we adjusted a few coupling caps and tweaked the second divider,
also, two of the 12AX7a tubes (EH) measure 15 on the tube tester where we should have numbers around 8 or 9, where they got these supecharged tubes and how this happened is a mystery to me, never seen this before, so we reduced gain by swapping in some nice Sylvania 12AX7WA premium mil tubes,
DC volts blue AC = green>
