Bo Deadly
I'm working on an API style mic pre but I added a relay to switch the separate windings of the EA2622 mic input transformer primary between parallel and series.
Is this something that is found in other mic pres and if yes what is it called?
I'm in the process of making the panel and I need to give the button a name.
Also, I assume the default position should be parallel for the full 1:7 boost but low Z and then when the button is activated it switches to series for higher Z / 1:3 boost. So I might call it "Z"?
