I just gave my vintage 1969 Dual Showman Reverb Pro (without master level control) to a tech and he said he tweaked the output bias of the amp by a little bit.
The amp now doesn't sound the same, it seems brighter and cleaner. It's lost the "magic". He reckons I might be imagining it, but I've had the amp serviced 3 times and this is the first time I've noticed a negative change. Also I compared recordings with the same setting and the sound has clearly changed.
Is it normal for a small bias tweak to negatively affect the sound like this?
And if it's just a very slight bias tweak, is there any reason why I can't just turn the screw slightly without bringing it back to the tech (it would be a huge hassle, and I don't have time to wait)?
Thanks in advance.
Thanks in advance.
