Murdock said:I assume the output impedance is 300 Ohm?
DerEber said:Does the 1M apply negative feedback from the output to the base of SF132?
I think it takes a friction of the output and feeds it to the input of that stage.
The SF132 works in Common emitter and so it flips the polarity of the signal.
So the signal feed to the base of the SF132 is reverse polarity to its input signal at that point.
