PCB mounting B9A tube socket with screening can
Norfolk - UK
For space saving reasons I have for years used gold pins directly soldered into a PCB for mounting B9A tubes. My newer design do not have this limitation so I am looking to add a  normal screening can. This will serve two purposes. As well as screening, the can will also hold the tube firmly in its socket. At present I have to ship the tubes separately to customers and they have to fit them. A good screening can that firmly holds the tube in place would allow me to ship with the tubes fitted. As well as providing extra screening  it would also allow me to supply  portable units.
So, anyone know of a readily available PCB mounting B9A socket with integral screening can?
Belton VT9-PT-C
You can get them here
http://www.banzaimusic.com/Micalex-Socket-Noval-PC-Mount-shielded-base.html
I attached the datasheet
  • VT9-ST-C.pdf
Tube Depot also has them:
https://www.tubedepot.com/products/belton-9-pin-miniature-chassis-pc-mount-socket
TubeAmpDoctor in Europe does them too:
http://www.tubeampdoctor.com/en/shop_Tube_sockets_and_Accessories_9_PIN_tube_socket/VT9_ST_C_Belton_Noval_socket_PC_mount_with_skirt_4325
A search for VT9-PT-C will bring up plenty. Looks like they take regular screening cans too. I like the built in lug that connects the can to the PCB, Use a nylon stand off on the other side and you have the perfect PCB valve container.
yeah they are compatible with standard shields, but the Belton shields are so shiny... almost a mirror
I like the coloured ones you can get nowadays. I have some lovely electric blue ones.
