electric_diaries
Heey guys, I am trying to repair one channel of my Quad 606 power amp.
Initially, I found that T9 had blown and shorted itself out. All terminals pretty much measuring 0Ω between each other. So I removed it. I also replaced R38 (2k2 in the top right corner which was burnt).
I replaced the fuse and turned it back on (still without T9) and the next one (T10) blew short straight away.
I am guessing it’s something to do with this T15/T16 voltage reference network, but I can’t easily just remove the load to test it without cutting traces.
Do you think I should I just try to replace T15/T16 next? Any suggestions for modern replacements to the ZTX652/752?
Thanks a lot!
Thanks a lot!
