Hey all,
I've been trying to find any online references to Shure mic transformers failing and have not been successful. I can't imagine at this low voltage windings shorting but I can't explain what I'm seeing any other way. I removed the capsule and tested it without transformer and its working. Don't seem to have any continuity issues on the capsule side (yellow/green/black). However I am getting a short beep on the DMM when touching black ground and white (which I removed from pin 3). The XLR male connector is removed. I do not get this beep on an SM57 I have. Mic sounds thin with no low end. I am assuming next step would be to remove the transformer. Can someone recommend safest way to do so and what to look for after removal? Any similar stories?
Jan
Jan
