pucho812
looking for some suggestions for subbing the following
Lundahl LL1517
Lundahl ll1538XL
Lundahl LL1517
Lundahl ll1538XL
LL 1538xl, wired 1:5, into a grounded plate/suppressor grid 7543.pucho812 said:looking for some suggestions for tubing the following
Lundahl ll1538XL
ramshackles said:Anything specific? (Lundahl have a few that can be used in place of LL1517 but are you looking for something other than lundahl?). Does it have to be the same/similar size?
rackmonkey said:Hey pucho, I looked through what I have and found the following 1:5 inputs, which are all still readily available in the US:
Cinemag CMMI-5C (150:3750 - not 600 ohm primary, but not sure of your application)
Cinemag CM-2560 (600:14.5k (also 150 pri)
Edcor MXcs 1:5
Jensen JT-13k7-A (also 150:3750)
As far as the 1517 goes, there are so many 1:1s with split windings I'll have to take some more time to look through them.
BT
