Reichelt No: BL 2X13G8 2,54 or similarMouser?? https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/1-215309-3?qs=sGAEpiMZZMs%252bGHln7q6pm8SOCK6aAoLgbIkv1jVEs%252bM%3d
I'm guessing 35v caps are acceptable for the electros outside of the marked ones.....and what, 50v+ on the polys and ceramics??? I'm hoping the lead spacing will dictate the diameter of caps??? pretty tight layout .....
I'm actually looking at the 3.68mm diameter for resistors??? guess it doesn't matter??
Any specs or parts reference/links to the bridge needed in the PS IDC socket and ribbon cable??? STROM 3-way connector?2-way and 3 way pcb connectorvarious 2-way and 3-way connectors and headers?
When I buy resistors at Mouser, I usually take those 1/4 watt resistors: https://www.mouser.de/ProductDetail/271-22K-RCReplace "22K" by the value you need.
I’m interested in 2 boards if you have enough.
Maybe I could just use it parallel 10vac secondary in lieu of the 9v ac wart??Or are these bad for noise and hum???
The only thing is that the 25k log pots are not in stock at Banzai.
Till, unless I'm doing something wrong, this is the panel for the Hammond box again.Dateien verwechselt?!
Thomas I hope it is okay.
yes I saw it to late changed the file in the post .... now it should work.Thomas I hope it is okay.
Hey thanks!!PM me if you want me to send you those pots... I have 2 now....... I can always get a couple more more... Knock on wood.....
Good work, Till! But it seems, you accidentally moved the panel's 4 original holes for the rack screws and chassis screws higher up as well.
Started by Svart The Lab
Started by mnats « 1 2 3 » Dynamic Processors
Started by mikefatom « 1 2 » The Lab
Started by fripholm « 1 2 ... 5 6 » Black Market
