Thanks Kron,
I saw that one too. Just that Kev's one looked a bit simpler (less parts count).
As for noise on the power line?!? Guess I have to build and try ?
M
Thanks Kron,
Yeah, I got your idea.I only meant to validate the principle. Kev's one does indeed contain only one stage of passive filtering (as opposed to Jakob's regulated and protected one), so you may or may not want to add some of your own.
Terry, I believe you. I would still advise against it because of the lack of PE. This is possible with a fully encapsulated enclosure, but not with a microphone, as you have a free-standing metal housing. In the event of a fault, B+ can be applied to the body and no protective mechanism will be triggered.Yes. He does do that. But he told me that he went with the wall wart and voltage multiplier because he didn't want any possibility of liability, and specifying a UL-approved wall wart, at least according to him, got him around that.
This is independent of the safety issue.And, as we saw in doorunrun's video, audio frequency noise was not a significant problem.
rock,@doorunrun , do your 5W resistors get very hot?
Thanks!rock,
No, not too bad. But, I'm glad the PC power supply enclosure has all that ventilation. I try taking some readings. The 5840 tube draws ~150mA, so for a 100R resistor that'll be ~2.25W.
Okay, that's already nice and warm!These are 5W wirewound resistors.
I put my DMM's temperature probe directly on the 110R resistor (the physically larger of the two) and measure ~75C or 168F degrees. This was after the supply had been turned on for about 10 minutes.
Yep, the problem was apparently (in a user report from the past) that the mic was unplugged immediately after use and then there were serious problems when it was plugged back in after a certain time. I can't find the forum post that described this at the moment, but I think B+ bleeder is basically a good thing.I haven't installed a bleeder resistor, but it's a good idea especially for B+. If the mic stays attached to the power supply the filament voltage will drop pretty quickly when power is shut off.
Holding one's hand above the case you wouldn't think it's that hot. Those resistors are rated for 155C max.Okay, that's already nice and warm!If the electrolytic capacitors are in close proximity, as in my case, they are already negatively affected.
+1I have them elevated off the PC board; always a good idea.
That’s almost nothing. I guess this will not affect the lifetime of the electrolytic capacitors in any negative way. Air is a pretty good thermal isolater! I would have expected more temperature on the capacitor surface, I am positively surprised.Addendum: Measuring temperature near the first electrolytic I'm getting 29C or 80F.
