Vac11 said:I used "double pins" from Aliexpress and bras rivet from Ebay. It was easy with grommet tool.
https://www.aliexpress.com/item/1000pcs-2-2-Inserts-Plug-Spring-Terminal-PCB-Solder-lug-type-thickness-0-3mm-Copper-washer/32709100694.html?spm=a2g0s.9042311.0.0.6ad94c4dk7Qcx9
https://www.ebay.com/itm/Leather-Crafts-Eyelet-Grommet-Setter-Tools-Anvil-Die-Set-Punch-Tool-1-5mm-40mm/332529819702?hash=item4d6c526036:m:mOALgZq4gSqfv9XM21Vd4Hw
https://www.ebay.com/itm/Copper-Brass-Vias-Rivet-Nuts-Through-Hole-Rivets-Hollow-Grommets-M2-3-M2-5-M3/172325490121?var=471144053545&hash=item281f664dc9:m:m9eJoXDwwYQxw8SeivnNGjw
Vac11 said:There was some interest. Boards has been sent to everyone who contacted me. Thank you.
To Lampas: Your PM box is full, I have contacted you on your email, but no response.... Did you receive the boards?
Do you use your provider's webmail or a client app such as Outlook or Thunderbird?lampas said:It appear that something is wrong with this board ... I could count 10 messages in my Inbox but the system count 50 and 100% even If I delete a few ones ...
abbey road d enfer said:Do you use your provider's webmail or a client app such as Outlook or Thunderbird?
Vac11 said:Ok, all my boards sold. Thank you. Btw. here is final result....
