samgraysound
I'm working on a Tascam Portastudio 488 mk2. It has a FF/rewind problem. It will run in either direction for about 3 seconds then stop. Playback works fine. I have changed the belt, lubricated the supply and takeup spindles and capstan shaft. I'm thinking maybe it is the rubber roller for FF/RW motor? It seems pretty dried out. What do you think?
Sam
Sam
