Hey guys,
so I've had these KRK RP5 monitors for a while and one of them is only working when it has warmed up and I can't really figure out what the problem is. When it's cold,there's a lot of noise and a little buzzing with just a hint of the audio signal that should be played. After a while, the signal gets louder and the noise disappers (apart from the normal noise floor of these monitors, which is pretty high anyway).
I switched out quite a few caps that looked iffy, scraped off the infamous hygroscopic "black gunk of death" and replaced a few rusty resistors that had fallen victim to it. I also reflowed the power transistor's connections for good measure, but the problem still persists.
To me it seems like maybe there is a cold solder joint that makes a connection again, when the solder gets a bit warmer? But I can't really see any obvious ones. So my question is: is the any part in particular that would exhibit this behaviour with a faulty connection or smth. that I could specifically look out for? Or am I barking up the wrong tree and it's something else?
Best
Jannis
Best
Jannis
