Opening my vault
analag
Mars
Here's an experiment I did a few years ago. Sounded nice but a little noisey
gyraf said:
6DJ8 hangin' off 230V/10KOhms is not a long-term-stable idea, I think...
The common grid tubes? Why not? If I'm reading the curves right power seems to be around about a watt (assuming a generous 10 mA from the degenerated K170Bs) in each tube, well within the 1.5 W rated for. I mean it sounds like a room heater of an input stage, but wouldn't it be fine long term?
I'm genuinely asking here, I have never built a tube amp just staring at curves here..
Edit:
Just noticed the current source connected to -50V... Thought that was ground. What's the current supposed to be?
FET-tube cascode, I think (or rather guess) Manley Reference Silver microphone uses similar topology except single-ended.
https://www.tubecad.com/2007/09/blog0119.htm
https://www.manley.com/pro/mrag/ (interesting way to adjust the polar pattern, that's a single diaphragm capsule)
https://groupdiy.com/index.php?topic=67316.0
Looks interesting for the use of  fet current sources - I would imagine it might have very low THD throughout.
I like the cross-coupled nfb from finals to first stage - interesting the way it is sourced from the finals' cascode.
The 5687 is an interesting 9pin tube with a lot of positive attributes except for heater power consumption.
I guess this is a moderately powered all-differential line amp with a 20K -ish load.
Some 6V6 in triode would be my personal choice - very linear, approaching the 5687 perhaps  ...  a pair of them is the same heater as a 5687 (dual triode) but can do more power.
I don't see any real problem with 230V as a plate supply voltage ... could be a little less I suppose.
Otherwise - interesting. Current sources and active loads  is the way forward to lower THD after all the obvious things are done.
I have one of analag's earlier takes on this kind of thing ...  a bit simpler than this one, but similar.
If one can get some reasonable  'ccs modules'  then well worth trying I think  ...  clearly a job for a little pcb with some good heatsinking  ....
Pete Millet does this kind of thing alot.
Anyway - all good to take a squiz at and arm-chair comment!
Back in the day  when we experimented with FET/BJT current sources, we ended up going another route because it always ended up "sounding" much more like (pressed) solid-state than tube
Have you actually built and heard this unit, or is it sim-game only?
Jakob E.
abbey road d enfer said:
Why don't we close this thread?
Nothing interesting comes out of it, even the OP doesn't seem to care...
C'mon old fella...whatsamatter.  I'm not done yet. I did fix it but do you care to know?
