Tubetec said:The only thing you need to be carefull about is that the bolt holding the transformer to chassis doesnt have any chance to make contact with the top panel if it did the enclosure would form a shorted turn on the transformer ,and a very large current would flow .
ruffrecords said:For UK mains the general rule is 3mm creepage/clearance so your 2mm gap is a little on the small side, however that is for naked wires. Since you toroid will be swathed in insulating material I do not think it will be an issue.
ian
