it would just change the axis or direction of the hum leakageWould mounting the toroidal vertically (i.e. perpendicular to the PCB) help?
[edit- if you can experiment with transformer location/orientation /edit]
That's right.So no good, I guess.
GOSS has lower conductivity than standard mild steel. It is preferred for cores because it reduces eddy current losses, but for "shorted-turn shielding", it's counterproductive.The external 'bands' used by a custom transformer manufacturer I used called it Grain Orientated Silicon Steel which is the strip they use for the core. I
When I was professional, I had the privilege of having custom-made xfmrs. I routinely asked the winders to use a 30VA rated core to produce 15VA xfmrs. Running xfmrs atCheap standard transformers use the least steel core they can get away with (cost) and run the magnetising current high so it is close to saturation. If the core dores start to saturate the radiated field gets much greater and if it gets into yopur audio path sounds nasty, like distorted mains hum rather than a gentle 50/60Hz 'sine wave'
When I was "professional" using custom made transformers I didn't have the stones to ask for 2x core in my sundry high volume power transformers. My employer routinely used trainloads of power transformers and long before my time had "cheap" hammered into the transformer vendor's design ethos. Which is good because I am cheap too, but there were a small handful of SKUs where I got them to be a little more generous. I recall one big console power supply where the universal transformer needed to hang at 50 Hz as well as be low noise. I got them to make one heavy rock for that PS.When I was professional, I had the privilege of having custom-made xfmrs. I routinely asked the winders to use a 30VA rated core to produce 15VA xfmrs. Running xfmrs at 8000 gauss makes them noticeably quieter.
like I said trainloads of heavy transformers...Peavey used to weld base plates on their transformers, solid as heck but expensive, i bet it kept lam rattle down, i wondered about core loss but i guess no biggy otherwise they no do,
i will be gosh darn Duke, your right, everybody is using the epoxy in the middle trick,
looky here from the cavern club, #705-18729 but i bet John knew that,
no wait, not expensive to weld, that's a mig bead i can see the splatter, they can train anybody to squeeze the trigger, but if were talkin bout stackin dimes, i want 30 an hour, plus full bennies because i won't be able to drive at night,,View attachment 105459
Is there any reasonably easy way (i.e not in an $1 million lab) to measure the magnetic field?. I mean an easy way other than listening tests. Maybe a 'scope with some DIY probes? Or even an audio interface + FFT software and some diy probes?
Indeed, evaluating stray fields is relatively easy, but the big unknown is how your circuit is sensitive to them.Is there any reasonably easy way (i.e not in an $1 million lab) to measure the magnetic field? I mean an easy way other than listening tests. Maybe a 'scope with some DIY probes? Or even an audio interface + FFT software and some diy probes?
Look @ #23, cheep plastic dynamic micIs there any reasonably easy way (i.e not in an $1 million lab) to measure the magnetic field?. I mean an easy way other than listening tests. Maybe a 'scope with some DIY probes? Or even an audio interface + FFT software and some diy probes?
Didn't get the hint the first time. Could recycle indeedI used the same sheet metal that was used for chassis
