Quayhog
REDDi parts specifications
« on: February 16, 2019, 02:18:54 PM »
What are (did) builders using (use) for REDDi power transformers?  specs? or specific available USA voltage brands?  Would my spare tube mic power supply for Sterling/Groove tubes PSM-1 work.  it powers a mic using a 5840 (6204) pentode. Im not sure of the voltage.  It already has 6.3 vdc for heater.
I have one of CJ special wound output transformers and Im about to start  the project.
I do have a 250ct @25ma, [email protected] Stancor. Its an ideal physical size for my chassis but the HV is a bit high.
Jonathan
Rob Flinn
Re: REDDi parts specifications
« Reply #1 on: February 16, 2019, 05:25:31 PM »
Jonathan
I used something roughly the same.  I just dropped the volts using some RC networks.
regards Rob
alexc
« Reply #2 on: April 12, 2019, 02:42:38 AM »
I'm doing a remote psu module for mine  ...  signal unit 2m away   ...   then with the fine tube and CJ output traffo
A Hammond psu traffo ...  60mA of HV and 2.5A of 6.3V heater,  I think   ...  is the smallest one I have ...  used it before in my la2a build.
It's 'over specified' and using a small SS regulator pcb   ...   so I have it able to power up another tube signal module as well.
My build is more of a CJeddi  ..  with an extra tube too  (as well)    8)
I ping therefore I am
« Reply #3 on: April 21, 2019, 06:15:01 AM »
CJ, you still making the OT for this? Is there nothing off-the-shelf?
"Kind of like going into Safeway at 4 in the morning and chugging a beer in the produce section; been there, done that." - CJ
"We're not making an atomic bomb, just cooking a few electrons." - PRR
Last post November 17, 2004, 08:03:53 PM
by clintrubber
Last post December 21, 2004, 12:51:04 PM
by erno p
Last post March 13, 2006, 11:36:30 PM
by Crusty2
REDDI DI
Started by dandeurloo « 1 2 ... 20 21 » Drawing Board
Last post March 30, 2019, 01:16:38 AM
by ARITOSOUL
