It all started a few months back whenI bought a second hand vari mu from a guy who owned it the last 10 years.
It is a model from the early 90ies with the 6386 tube and older (yellow) meters. It worked fine altough i heard little distortion on one channel so i decided to let it check by the official manley partner here in germany called S.E.A. (www.sea-vertrieb.de). They immediately saw which parts had to be replaced and i sent them the unit.
Well, after some time they recapped the unit, replaced the tubes with new old stock and months later sent it back to me. Fully calibrated like they said and functioning fine.
This was the first tour..
To my bitter disappointment the unit arrived with broken tubes as the top lid was squeezed a little into the case. So i decided to tell them what i saw and they accepted to take the unit back for another repair. They ran a lot of tests, made the calibration and some weeks later i was sent back the unit again with working tubes (now with placeholderes from top to bottom lid.. )
Second tour..
However, now i noticed some weird behaviour of the VU meters. The left meter occasionally moved from 0 GR completely to the left and stayed there. After some time (mostly after restarting the unit) it went back on zero. This was the first time i experienced that behaviour, before the repair the meters were functioning without problems. So i called the responsble guy again, described the situation and asked for help. At first he wasn't willing to take it back but after some talking he offered to give it another shot.
They ran a lot of tests, contacted manley labs in USA and tried to reproduce what i saw but they weren't able to make out the problem. He offered to replace the meters at my cost but i wasn't willing to pay for something i wasn't responsible for. So it took several months until they finally replaced the meters with new ones from manley. They didn't see any problems with the meter. They even tried to place the device in different angles on the rack (i have mine slightly lifted in the rack, not flat)
Third tour..
As i got back the unit, the first hours everything was fine, until now when i had to see the exact same thing happen again...
I found out that when i slightly tap on the meter or touch the case of the unit or some switches, it immediatley pops up to zero. But unly so far, until it goes back to the left again... I am so clueless at the moment !
I'm really not a fussy or petty person but i just expected my unit to be completely fine after spending several hundreds of euros on a full service! I know it is an older device but still, can it be so hard for an official manley service shop ??
I didn't dare to call them a fourth time. I thought i'd try asking you guys first about what i should do or try.. ??? ??? ??? ???
Ansgar
Second tour..
Third tour..
Ansgar
