Neotek Elite EQ, Room for improvements?
« on: March 02, 2019, 05:47:40 PM »
Hi guys,
I recently bought a late eighties Neotek Elite console. I got a nice deal on it and so far I'm really enjoying it!
The EQ is actually quite good. I like it up to about 4-5k, ish, but above that it has a tendency to sound a bit harsh. I love the sound of my Sontec clones but the Neotek is pretty much the opposite.
I'm not looking to do a total rebuild but any input on mods, large or small, is very appreciated.
I have been thinking about replacing the TL074 for the high and high mid band to something more "sexy" that might do something, and also maybe try to replace the capacitors for styrflex. What do you think?
jensenmann
Re: Neotek Elite EQ, Room for improvements?
« Reply #1 on: March 03, 2019, 08:26:22 AM »
Sounds like a good plan. You may want to try mica or FKP (foil/foil polopropylen) caps as filter caps as well. Use whatever your ears like better. I´ve used OPA2132/4 or in very similar circuits with good results. In your case you´d need OPA4134 on adaptors since those chips are SMD only, unfortunately. Make sure that you add 0,1uF ceramic caps from B+ and B- pins of the new chips to ground. These are important to avoid oscillation.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
« Reply #2 on: March 03, 2019, 09:24:46 AM »
Thanks for your advise Jens! And also thanks for contributing to the Harrison Ford filters, I have made a small PCB prototype without the balancing ICs for my Neotek. Not sure it will work out cos of panel space but I'll see what i can do.
Alright I'll try those caps and see if i can find an easy upgradeable IC for  the TL074. I know that Texas instruments makes a "HIFI" version of the TLX series that is a common replacement on the Neoteks as they are prone to occilate with modern OPs. And ill se if i can find an OPA4134 and adapters to.
« Last Edit: March 03, 2019, 09:59:09 AM by Studio Mollan »
« Reply #3 on: March 03, 2019, 09:29:55 AM »
The Texas Istruments TL074 upgrade is called TLE2074
jensenmann
« Reply #4 on: March 03, 2019, 01:43:11 PM »
That´s another good chip for that purpose. They have lower power consumption than TL07Xs which occasionally is very handy. I´ve used them in circuits when the increased current draw of OPAx134s is a no-go.
Jens
Quote from: PRR
« Reply #5 on: March 03, 2019, 03:40:44 PM »
Ok then! Thanks again!
« Reply #6 on: March 04, 2019, 11:00:55 AM »
Do you think i will need the 0,1uf ceramics for the TLE2074 as well?
jensenmann
« Reply #7 on: March 04, 2019, 01:24:41 PM »
It´d be risky not to use them. The TLE has a higher gainbandwidthproduct which means (simplified) that it´s more prone to oscillations than the TL072. These TLEs have not been tested in this particular circuit, so the ceramics are your safety net.
Jens
Quote from: PRR
« Reply #8 on: March 04, 2019, 04:47:53 PM »
Alright. Thank you, i will make sure to add them if/when i start to experiment.
Blackdawg
« Reply #9 on: April 15, 2019, 06:48:48 PM »
Should be able to get theOPA2132/4 pre soldered on DIP8 boards here: https://www.cimarrontechnology.com/browndog-970601-so8-to-dip8-adapter
Super cheap too and lots of other modern options you could try too.
jrasia
« Reply #10 on: April 16, 2019, 08:36:21 PM »
I got tons of new brown dog dip8 adapters for sale if you want to do a whole console :)
Last post September 28, 2010, 06:35:21 AM
by EEMO1
Last post October 11, 2011, 10:04:28 PM
by gemini86
Last post March 30, 2013, 08:22:50 PM
by gemini86
Last post April 23, 2018, 01:55:57 PM
by jackson5
