Front Panel Designer/Express, Schroff vs. Fischer
The actual postion of the holes used to fit the panel to the rack are identical. But the additional holes used to connect the panel to an enclosure are slightly different I believe.
I thought that might be the case, but I saved the file with both formats, and had them open in 2 tabs, and zoomed really far in, and switched between tabs and could not see a difference.
Simplest way to check is to click on each hole and read its parameters.
