G.TEN 500 series graphic eq
« on: May 05, 2019, 03:52:22 AM »
Hello groupdiy'ers!
I'm happy to announce:
Garash G.TEN - ten band graphic equalizer in 500 series format.
Great sounding and easy to set eq with all important music frequency points.
It’s great for shaping drums, guitars or any other sources where you need great sound and fast setup.
Schematic was LTspice emulated and carefully tuned. Eq principle is based on ic gyrator filters. Eq is proportional-Q (wider Q on low boost/cut and narrower Q on high boost/cut). Such eq principle became especially popular from the mid of 70s when the famous console module was invented by Al Davis. You know what module it is :P
At this moment 50ty pcs sold. We are preperring third batch that (I hope) will be available in September 2020.
Latest build manual (V2.1):
https://www.dropbox.com/s/wz5ivwp9eug4fos/G.TEN%20V2.1%20assembly%20guide.pdf?dl=0
Feel free to ask and comment.  If you have an interest - PM.
Also kit is available through our distributor:
https://www.facebook.com/diystudiotoys/
Cheers, Igor
« Last Edit: August 14, 2020, 09:38:20 AM by dirty1_1garry »
TillM
Re: G.TEN 500 series graphic eq
« Reply #1 on: May 06, 2019, 03:24:14 AM »
This looks good.
« Reply #2 on: May 06, 2019, 10:11:25 AM »
This looks good.
Thanks! Will post here some further steps
echoplex
« Reply #3 on: May 08, 2019, 06:19:49 PM »
I just wish its faceplate was black.. but otherwise it is perfect!
Will very likely order some off these throughout this year  8)
« Reply #4 on: May 10, 2019, 01:06:19 AM »
Feel free to contact)
« Reply #5 on: May 11, 2019, 02:18:05 PM »
« Last Edit: May 11, 2019, 02:28:23 PM by dirty1_1garry »
« Reply #6 on: May 21, 2019, 01:21:57 PM »
Winetree
« Reply #7 on: May 21, 2019, 06:23:51 PM »
I'd be interested in 2 kits.
Can't figure out how to pre-order. Not on Facebook.
« Last Edit: May 21, 2019, 06:28:20 PM by Winetree »
« Reply #8 on: May 22, 2019, 02:09:00 AM »
PM send
OneRoomStudios
« Reply #9 on: May 23, 2019, 08:50:08 AM »
Hi Igor,
What is the price on these? Thanks!
« Reply #10 on: May 23, 2019, 09:48:20 AM »
Hi Igor,
I did not post price here as that's not a white/blck market. I think it's correct.
PM send.
« Reply #11 on: July 16, 2019, 07:25:01 AM »
First batch sold. Assemble manual and BOM added. Check first post.
echoplex
« Reply #12 on: July 31, 2019, 11:53:27 AM »
this is awesome ! :)
« Reply #13 on: July 31, 2019, 06:51:17 PM »
thanks, you are welcome!)
Winetree
« Reply #14 on: July 31, 2019, 07:01:59 PM »
Will there be a second batch?
« Reply #15 on: July 31, 2019, 07:04:12 PM »
yes, prepare for second batch. I hope in september it will be availble. You can send me your e-mail and I will send a massage with notification
« Reply #16 on: August 13, 2019, 01:19:33 PM »
last G.ten from first batch
On sale, check Black Market.
Bobby Baird
« Reply #17 on: August 20, 2019, 07:34:43 PM »
G.TEN received! One question. I will be using the B output option with 2520 & 2503 output transformer. I noticed that there were 2 - .1uf ceramic capacitors above the dip8 that 1246 socket. I believe the build manual says to leave these off board. Just want to confirm that I should remove them, or if it is ok to leave in circuit? Below is picture with circled components in question.
Thanks again Igor!
« Reply #18 on: August 21, 2019, 03:07:16 AM »
Thanks again Igor!
Hi! Congrats!
In a such configuration you should install 0.1u near 1246 and do not install them near 1646. Like it showed on page 27 (I've added additional image, see attached).
One more comment - on page 43 there is a schematic for wiring 2503 as 1:2. There is a mistake - that's necessary to ground only one unused wire (ORG or YEL), NOT both. If you will connect both you will get a short circuit at one secondary (that's safe for transformer) and you will read -6db instead of +6dB trx gain.
Bobby Baird
« Reply #19 on: August 24, 2019, 07:01:00 PM »
Sounds awesome! Ruler flat engaged. Looking forward to getting a couple more to sit on snare and bass drum tracks.
« Last Edit: August 24, 2019, 08:08:09 PM by Bobby Baird »
Last post October 02, 2009, 05:56:02 PM
by jsteiger
Last post June 01, 2013, 12:29:43 PM
by justanalogue
Last post August 21, 2019, 11:56:34 AM
by dirty1_1garry
Last post February 26, 2020, 02:41:28 AM
by Joekkel
