BluegrassDan
First time designing a PCB - check my work?
« on: August 02, 2019, 04:35:04 AM »
Hey guys,
This is the first PCB I've ever designed. Just curious to have my work checked.
Traces are 60 mil. 240V on B+, total heater current will never be more than 2.9A with four channels.
BluegrassDan
Re: First time designing a PCB - check my work?
« Reply #1 on: August 02, 2019, 04:35:58 AM »
And the schematic...
gyraf
« Reply #2 on: August 02, 2019, 06:32:06 AM »
You'll probably want bigger pads for all things heavy..
Jakob E.
BluegrassDan
« Reply #3 on: August 02, 2019, 09:17:46 AM »
Bigger pads for the transformer at bottom left. How about all the other components? Beef them all up, including the resistor pads?
gyraf
« Reply #4 on: August 02, 2019, 10:01:00 AM »
yeah, for proto work, it's always nice to have good space to solder onto. And you're not running tight on space there anyway..
Jakob E.
BluegrassDan
« Reply #5 on: August 02, 2019, 11:56:13 AM »
Here's another version. Increased most of the pad sizes to 120 mil. Made the tube pads circular and increased their size for more surface area.
« Reply #6 on: August 02, 2019, 05:20:06 PM »
I am a little concerned about the clearance between the heater traces and the first anode of the bottom tube. I think perhaps you should neck the tracks in this region.
BluegrassDan
« Reply #7 on: August 02, 2019, 06:07:52 PM »
How narrow (mils) can I get away with? I thought about doing some more creative heater routing with vias if necessary.
« Reply #8 on: August 02, 2019, 07:09:03 PM »
Well it is only 150mA of current. What width are they now?
boji
« Reply #9 on: August 02, 2019, 07:39:47 PM »
+1, but I'm no expert.  Will you have a soldermask on the proto?
Edit: Adding a via would solve the squeeze; have one of them come from the other layer.
BluegrassDan
« Reply #10 on: August 03, 2019, 02:01:19 AM »
All the traces are 60 mil.
« Reply #11 on: August 03, 2019, 03:21:28 AM »
you can look at this tool, http://www.saturnpcb.com/pcb_toolkit/
« Reply #12 on: August 03, 2019, 04:27:33 AM »
For signals. 20 mil is plenty. I think you can safely neck those heater traces to 30 mil where they pass between tube pins.
Not wishing to put a spanner in the works but when I have two  like yours sharing a heaters I usually place them on the baord with the heaters facing each other. The way you can have a pair of short fat traces directly between them.
Edit: So you would just need to rotate the bottom one through 180 degrees.
Last post December 05, 2007, 05:16:15 AM
by ChrioN
Last post August 29, 2008, 01:33:05 PM
by guavatone
Last post May 11, 2012, 10:09:39 AM
by steveh
Last post January 03, 2019, 06:51:36 AM
by jarvis
