Hi all,
I'm wanting to add some LED output level metering to some mic pre's (1073s and alike).
The LM3915 seems a good shout for LED metering - pretty much a plug and play design, and it works off a single rail power supply (like the 24VDC one I'm using to power the pre's).
I read here (https://groupdiy.com/index.php?topic=48577.msg613543#msg613543) that I need to rectify the audio signal before it reaches the LM3915. Assuming this is the case, my first instinct would be to buffer the signal with a 5534 style op-amp...but this needs +/- V to power, which isn't a supply I have available.
So, my questions are:
- Do I really need to buffer the input to the LM3915? Why is this?
- If I do need to buffer, is running an op-amp on a single rail supply a clever thing to do? I've never done this, but I've read there are a few ways to do it.. I'm worried this might mess up the supply though - obviously the priority is quiet mic pre's.
- Is using the 24V mic-pre power a good idea for the LM3915 in the first place, or again is it just going to mess up the supply?
- Is there another (better) way to do all this that I'm missing? Space is limited so 5 or 6 LEDs (just for a rough indication of level) was my plan.
Thanks folks,
R
Thanks folks,
R
