Jensen & Cinemag output transformer same pcb mounting holes?
elskardio
Montreal - Canada
Hi Guys,
Could someone confirm that Jensen (JT-11) and Cinemag (CMOB, CMOQ) output transformer have the same distance between the 2 mounting holes for direct pcb mounting.
I'm using cinemag at the moment and I want to make sure my PCB is compatible with Jensen as well.
Thanks  ;)
MountCyanide said:
Yes, if you're talking about the Cinemag 2 (CMOB-2, CMOQ-2) they are exactly the same, mounting-wise, to the Jensen D sizes (JT-11D, JT-123D, etc.)
Thanks MountCyanide
I just got a response from Jensen ;)
FYI, if your planning to use the JT-11-E size one day, they have the mounting holes spaced at 1.062" (27mm).
