substitute
Eagle Lib for Alps mixer style pushbutton switches?
« on: November 10, 2019, 09:17:58 PM »
I'm looking for an eagle library for Alps SPUN switches. You know, the pushbutton switches that are in like practically every single mixer/console, but I'm coming up empty. Seems like it's gotta be out there.
This is the part I'm talking about...
https://www.mouser.com/ProductDetail/ALPS/SPUN191400?qs=sGAEpiMZZMvxtGF7dlGNpjiK57Z41phvVwfoMjW8SmU%3D
I noticed there's this ECAD pcb symbol that can be downloaded, but I'm really confused about how to get that into eagle. Seems like there's some sort of utility application but it only works on PC (I'm on a mac)
The obvious thing is to just make the library myself but this style switch is so common I feel like it's gotta be out there already.
Any advice?
Rocinante
Re: Eagle Lib for Alps mixer style pushbutton switches?
« Reply #1 on: November 13, 2019, 11:18:21 AM »
Try looking for shadow switch lib. I think that's what they are called. F2uee? I think that is another. I'd have to open it up and see but I use them all the time. Maybe try searching the forum for Harpo lib. Regardless it has some very valuable footprints in it.
If there's a harder way to do this, I haven't found it yet.
abbey road d enfer
« Reply #2 on: November 13, 2019, 01:42:15 PM »
Any advice?
You should; it takes anly a couple minutes and you know you can make it exactly how you want it, placing the reference point exactly where you want it and make the pads exactly how to make your PCB fab happy.
moamps
« Reply #3 on: November 13, 2019, 05:54:54 PM »
I did it for you.
Also, there is a library on Eagle site which contains few push buttons.
http://eagle.autodesk.com/eagle/libraries?utf8=%E2%9C%93&q%5Btitle_or_author_or_description_cont%5D=toneluck&button=
substitute
« Reply #4 on: November 13, 2019, 09:42:14 PM »
I did it for you.
Cheers buddy, thank you, works perfect!
And thanks for all the library recs everyone, much appreciated.
Last post July 27, 2008, 05:13:25 PM
by Brad McGowan
Last post June 30, 2010, 05:50:41 PM
by mitsos
Last post June 14, 2011, 10:50:20 AM
by abechap024
Last post October 30, 2011, 02:36:46 PM
by gemini86
