neumann w 495 stb eq - how do i connect power supply?
« on: March 21, 2020, 04:41:10 AM »
Hallo,
i have a neumann w 495 stb stereo equalizer,
i did find the pinouts and i understand how i can connect xlr cables,
but i don't understand how the power can be connected,
on the pinouts i only see one pin thats connected to +24 volts,
if i buy a simple 24v power adapter i have two wires
can you please explain me how i can fix this?
With friendly regards,
Jeroen
Re: neumann w 495 stb eq - how do i connect power supply?
« Reply #1 on: March 21, 2020, 04:58:03 AM »
i have  a "pin adapter" , there still are some wires connected but i'm not certain that these are all at the right spot
for example on the 4th pin from the left i see there are still 2 wires connected: (this should be the +24 volt)
(white ............  brown ...............blue+blue+red .................. red+red
for what reason would i connect two wires to the +24v connector?
moamps
« Reply #2 on: March 21, 2020, 05:24:47 AM »
+ pole of the power supply goes to pin 16, - pole to pin 15
« Reply #3 on: March 21, 2020, 05:32:28 AM »
hi,
thanks for the info,
and if i'm correct pin 15 "0v"  is the ground of the xlr output 2
so these two are connected together,
do i need to connect all the other "0v"  to pin 15 ?
moamps
« Reply #4 on: March 21, 2020, 05:40:54 AM »
No, they are internally connected.  You may test it using a DMM. "0" at audio pins are used for cables shield connecting.
Last post June 23, 2004, 11:39:12 AM
by gyraf
Last post November 27, 2009, 08:59:11 AM
by mitsos
Last post July 28, 2006, 08:30:02 AM
by Robin Reumers
Last post July 03, 2018, 07:44:53 PM
by JW
