synthiaks
Signal generator Impedance Question
« on: May 19, 2020, 04:27:15 PM »
This is probably a stupid question but I'm asking it anyway.
I have a BFE Kompressor that say in the calibration notes that output Impedance of the signal generator used should be 10ohms or less.  Most of the generators i have come across have 50 or 600Ohm s output Impedance. Is this because i only have and have seen the cheap ones or How does this 10Ohm come about?
S
« Last Edit: May 19, 2020, 04:31:40 PM by synthiaks »
"ex observer in silence"
JohnRoberts
Re: Signal generator Impedance Question
« Reply #1 on: May 19, 2020, 04:38:31 PM »
10 ohms  is not typical for professional signal generators. Good ones are switchable between 50 ohm or 600 ohm.
Use 50 ohms
Maybe get a different compressor. ::)
Cancel the "cancel culture", do not participate in mob hatred.
synthiaks
« Reply #2 on: May 19, 2020, 04:54:50 PM »
Thank's John!
Ok, I will use the 50ohm on My generator.
Do you have any idea where the 10ohm comes from? The BFE/Filtek company did a lot of German Broadcast equipment and their Specifications are quite detailed. No low quality equipment.
S
« Reply #3 on: May 24, 2020, 08:05:16 PM »
You can add a buffer to your signal generator with a good opamp like the LM4562 and a 10 ohm resistor output, the distortion and noise should be negligible
gyraf
« Reply #4 on: May 25, 2020, 05:06:55 AM »
If really needed, and if you have plenty signal level in your generator, you can always lower signal source impedance by passively attenuating - e.g. 40 Ohms in series, then 10 Ohms to ground - will give you a ca. 10 Ohms source at 1/5 the original level.
But as mentioned above, you may not need it..
/Jakob E.
JohnRoberts
« Reply #5 on: May 25, 2020, 10:16:27 AM »
Any decent quality audio amplifier that can drive loudspeakers will have an output impedance in the mOhm range.
As Gyraf suggested a simple resistive pad can also drop the source impedance to 10 ohms.
It might be interesting to see of you measure any difference between 10 ohm and 50 ohm.
synthiaks
« Reply #6 on: June 01, 2020, 07:39:23 AM »
Thank's for all the help!
I tested it roughly with the 50ohm generator. When i have time i might get back and do a test with the resistors
S
Last post September 04, 2005, 04:02:34 PM
by yan_b
Last post December 14, 2006, 10:59:33 PM
by Quince
Last post June 08, 2010, 07:14:00 PM
by dmills
Last post April 15, 2019, 03:44:32 PM
by Tubetec
