Dachman Audio Capsules?
« on: November 03, 2020, 12:43:54 AM »
They are shipping from NY at 169 a piece.  6 micron.  Anyone ever try these?
https://www.ebay.com/itm/Dachman-Audio-Neumann-K87-K67-Replica-Mic-Capsule-for-U87i-DIY-and-Upgrades-/114397853324
gyraf
Re: Dachman Audio Capsules?
« Reply #1 on: November 03, 2020, 04:52:37 AM »
Another instance of the peluso business model?
/Jakob E.
« Reply #2 on: November 03, 2020, 12:58:19 PM »
I bought one of these last month and it turned out to be the best K87 capsule that I have (still waiting for the Heiserman HK87, was est. 8-weeks lead time).  It looks and sounds very much like the 3U Audio K87.  I have several MP RK87 and various cheaper eBay K87 capsules, but I think it was worth it.  He will negotiate on price, too.
« Reply #3 on: November 03, 2020, 04:35:45 PM »
It does look remarkably similar to a 3u K87.
Gus
« Reply #4 on: November 06, 2020, 11:45:58 AM »
I did a google search for Dachman audio found a few links
look at the linkedin one that shows up
Recording Engineer
« Reply #5 on: November 06, 2020, 12:22:58 PM »
Ah yes, the focus of marketing does cast doubt. I personally won’t consider trying unless some people we trust feel the urge to take the plunge for some reason and report back.
Gus
« Reply #6 on: December 25, 2020, 07:13:00 PM »
found this today
https://dachmanaudio.com/product-category/microphone-parts/diy-microphone-kits/
https://dachmanaudio.com/shop/da-87i-diy-microphone-kit-for-u87/
It has the Neumann schematic fragment (copyright issue?) not a redraw
I don't see the CC semiconductor in the schematic in the parts picture
So is it the 24VDC Zener or 33VDC Zener circuit?
tywraps to hold the transformer?
« Last Edit: December 25, 2020, 07:38:48 PM by Gus »
« Reply #7 on: December 26, 2020, 12:00:32 AM »
It looks identical to the poctop pcb including the passive components used on the poctop BOM. I built a poctop d-u87 for a friend a few weeks ago and used their k87 which happened to be on sale for $60. It sounds perfect. Practically indistinguishable from the beezneez k87 in my own. Not sure what their deal is.
RuudNL
« Reply #8 on: December 26, 2020, 05:09:23 AM »
No serious microphone manufacturer would fasten a transformer with tiewraps...
There is a solution for every problem!
http://www.vansteenisaudio.nl
shabtek
« Reply #9 on: December 26, 2020, 05:56:37 AM »
A novice diyer should try a little harder too.
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
Gus
« Reply #10 on: December 26, 2020, 01:06:53 PM »
RuudNL
« Reply #11 on: December 26, 2020, 02:18:57 PM »
Does it have the same amount of HF boost as the original Neumann K87 capsule?
I once tried a K87 from Maiku, but it was quite disappointing.
I contacted them and the answer was that you need to change the HF feedback.
Well, in that case it is not a good replacement IMHO...
Recording Engineer
« Reply #12 on: December 26, 2020, 09:14:39 PM »
I don’t know... If painting by numbers, you’re right. But if doing that, might as buy the original when still easily and readily available.
« Reply #13 on: December 26, 2020, 10:31:04 PM »
What’s a good way to secure a transformer?
One of my mics has something like this with the transformer inside jus sitting in it.
I’m scared because it’s not wrapped in anything.  The transformer metal is touching bare to the shield inside.  Is that okay?
RuudNL
« Reply #14 on: December 27, 2020, 03:47:49 AM »
Just look at the way a decent microphone manufacturer does it!
(Securing a transformer with tie wraps is a very amateurish solution in my opinion!)
RuudNL
« Reply #15 on: December 27, 2020, 04:10:32 AM »
There is a 'small' price difference...
Recording Engineer
« Reply #16 on: December 27, 2020, 12:29:38 PM »
I know. This is why people try alternatives ways. Plus, it makes things more interesting and inspires more creativity.
If just looking for a true replacement, I’m not sure anything but the original is going to satisfy. Then it gets down to how original the product is within the same manufacturer. Then we’re at gearslutz level. Slippery slope.
« Reply #17 on: December 27, 2020, 02:00:50 PM »
I don't have any other microhones with a transformer in it.  All of the mic pics online have the shield already covering the transformer.
Couldn't you just help me out and tell me?
« Last Edit: December 27, 2020, 02:17:28 PM by Erik2345 »
« Reply #19 on: December 27, 2020, 02:24:44 PM »
http://www.coutant.org/akgc12/index.html
2nd picture, under the red and blue wire
or
http://www.saturn-sound.com/images%20-%20microphones/akg%20c12%20transformer%20types.jpg
That's not the mounting style im talking about...I found plenty of those...but I want to know how one is supposed to mount the transformer using the metal shielding.  This is how mine is mounted.  Mine has a noise shield like this...but the transformer inside is bare metal, touching bare metal of the shield.  It's simple just sitting in there, and I can hear it move around when moving the mic.
Last post May 11, 2005, 06:44:42 PM
by doshu
Last post September 28, 2005, 05:32:43 PM
by rodabod
Last post February 11, 2019, 07:09:18 AM
by Carl H
Last post April 21, 2020, 10:25:16 AM
by Lelandletham
