Spencer, please allow some remarks,
your "22kOhm log pot" will be a rev log taper pot,
the +/- orientation of C3 is depending on type of DOA used,
125uF is a last century parts value for C1 and C2 (btw with original parts value 12.5uF) and fitting a 35VDC capacitor rating will allow the use of +/-24VDC supply rails as well at assumed same cost,
zobel parts values of R3 and C5, if needed at all, is depending on type and series or parallel hookup of T1,
J2 pin1 connects to shield, not ground (different symbol/node), that is not neccessarily the same in this spot,
C6 and C7 will be placed close to XLR-in, maybe not on pcb, caps common side connected to shield, not ground (in order to more effectively block/reduce rf coming in from the outside world, fi no mobile phones back then...)
best regards
