Api-312 500 series style build
cant seem to find a schematic for the 25k rev log stepped gainswitch?
could anyone post please? as i want to make a couple form these lorlins
this is what ive guessed at:
1. 15k
2. 4.7k
3. 2k
4. 1.2k
5. 750R
6. 510R
7. 360R
8. 240R
9. 180R
10. 120R
11. 82R
does that seem about right?
Edit: these values are pretty close and should work
Just waiting for 120pf and 220pf styros, have put in some temporary txf that should get signal through until I come up with a winding plan for the output txf.
Building the psu today and hopefully testing with some power as I can just pop in some poly 120pf and 220pf to get it working.
Will post some pics soon.
well it seems there are many errors in that schematic so im following the api version now as it all seems correct.
1st channel i've powered up and had a slight fault on the instrument input which was just a dodgy connection to gnd.
i'm running at 16v at the moment, whats the advantages of running at 18v? just curious.
working on the 2nd channel now and the case, need to drill a few holes etc and mount the pcbs in there.
also going to wire the polarity but i notice the api VP312 version has the polarity before the output txf as with the access 312 versions they have the polarity before the input txf? does this really matter? is there a preference?
will wire in the 48v and pad switch as per the VP312.
i have noticed on the VP312 shematic R3 is 10k, where i have used 5.1k here so will change and see if anything changes?
stepped switched work great with lorlins.
And yes I get that it's not 500 series yet, but I havent managed to get into my shed to do metal work.
Just managed to get hold of some new brass to make some u47/fet47 headbaskets, so got a couple of weeks next month were I'll hopefully knock out a few mics and do the metal work.
At the moment to get them working using this 2U enclosure which I was going to put 2 x neve 1290 in.
marginal higher headroom, if needed at all, or some smoke if your type of DOA isn't designed to take this amount of +/-18VDC (=36VDC differential between rails) supply voltage.
with polarity flip before the output transformer, you could change polarity of the line input as well.
already told you, this resistor is part of the zobel network and its parts value is depending on type of transformer and if you hook up the primary windings in series or in parallel.
nice. My take on this subject would be based on some calculation for a linear dB increase, like this excel sheet. Just overwrite the parts values or number of step positions in the yellow cells to match your plan.
best regards, Harpo
after a few mishaps with volkers PSU, i blew a few LM317, a 240R got very hot and a 100uf cap exploded!!
found my errors, 50k pot rather than 10k, changed the other 10k pots to make sure and replaced all the other bits, works like a charm!!
Both channels now working, just need to wind another input txf for channel 1 as its not looking pretty!!!
Now onto the 48v, Pad and the polarity, nearly done but i do keep smelling something getting hot?
need to keep an eye on these 2520 opamps!!!????
channel 2, BD139 and BD140 are getting very hot!! ??? im using Gar2520s.
will have a poke about and see what gives!
Either an assembly error or the bias is set too high.
Switching at the input can cause loud pops.  I always put polarity reverse at the output.
I haven't had a chance to poke around yet on ch2 but I'm only feeding 16v in at the moment and it takes a few minutes for the bd139/40 to get hot.
Ian, you say bias could be set too high?
Do you mean on the 2520 or elsewhere?
I dont have a bias pot or anything?
Yes, I'm going with polarity before output.
Will wind input txf this morning, change it over then check ch2 and compare voltages to ch1, hopefully will find a little mistake!
I assume the BD139/140 are on the 2520? So if they are BOTH getting hot then they are passing  too much dc current. Did you build the 2520 yourself? Maybe that is where the error is.
IAn
