Milkmansound Well-known member Joined Jan 29, 2005 Messages 449 Location San Francisco, CA Mar 22, 2005 #1 do you think its possible to get +/- 15VDC and +5VDC from a single 15 (or more) volt wall wart?
PRR Well-known member Joined Jan 30, 2010 Messages 11,143 Location Maine USA Mar 22, 2005 #2 Use a 10V-12V AC wall-wart and do something clever with diodes and caps. It's done all the time. 9VAC gives about +/-12VDC which is usually quite ample.
M Mark Burnley Well-known member Joined Jun 3, 2004 Messages 820 Location Liverpool UK Mar 22, 2005 #3 Yes, With a single AC input supply and some diode/voltage multiplier tricks you can do it all. Check this schematic from Rane for some inspiration: http://www.rane.com/pdf/ms1bsch.pdf :thumb: Mark
