10-48 UNS 2A tap
peter purpose
London
Gentlemen,
I've searched high and low for a 10-48 UNS 2A tap, yet find nothing but charts.
Do any of you know of a secret machine tool supplier that could sell me one or two?
Any and all help welcome.
peter
actually i found some at Mcmaster-carr, but I don't know if they ship to the UK
Chamfer Each
Taper 2595A745 $20.20
Plug 2595A746 20.20
Bottoming 2595A747 20.20
Peter,
What is that bad boy for?
I could not find any reference in Machinery's Handbook for that thread.
My copy (twentieth ed) only references UNC @ 24 tpi and UNF @ 32 tpi. Both are spec'd as 2A class fit.
Perhaps this is a custom threaded part. Or a specialty for one industry or another. Lots of weirdness once you cross the custom threshold! You may need to find the original supplier of the hardware or have a machine shop make a custom tap or die for you. Custom tools = $$.
Keef,
I have both tap and die for 5/8-27 that came from the local machine supply house. I don't think they were terribly expensive at the time. I seem to remember around $50 for both. I think the place is even on the web, I think "Machine Supply Specialty" or specialties.
Svart... :thumb: :thumb: kinwellahnsum
Irv..... <<What is that bad boy for? >>
It's for an ultra miniature toggle switch, to lose the front nut.
Grassy arse boys.
peter
Firstly:
Phwoooargh!
Secondly:
Irv: -Thanks, -Top work!
Thirdly:
Peter "Lose the nut"...
Nuff said.
http://www.groupdiy.com/index.php?topic=3076&highlight=microphone+tap
For Keith's post
Are you sure it isn't a Wintworth thread?
Seroiusly, weld that hole shut, drill and tap a 10-24.
Want something else thats impossible to find?
Look for a die to re-thread a 1966 Bucik Special left front spindle.
$10,000 to the first guy to find it.
It's been thirty years and I'm still lookin.
[quote author="CJ"]Are you sure it isn't a Wintworth thread?
[/quote]
Is you tinkin Whitworth?.... No idea.
I didn't pay attention in metalwork class.
I don't have a hole to weld shut. I have a switch with a 10-48 thread and wanted to screw it flush mount into a panel.
I might just try and tap it in with the switch and squirt some loctite in there.
peter
[quote author="peter purpose"]I might just try and tap it in with the switch and squirt some loctite in there.[/quote]
When I saw that picture of Sophia, I briefly considered tapping it in with my â$$ and doing something very similar... but I wasn;t thinking of loctite, I can tell ya... :shock:
You got a spare switch or two?
Some cutting lubricant and a couple of dremeled-in slots into the switch threads on the neck will probably work, if the switch has a fairly hard thread, and you're going into aluminium. ("I" stressed for the English-impaired).
Then wash it out to clean the lubricant, and your suggested loctite should be just dandy. -Do you have a piece of scrap to test the process out on?
Keef
I used to work with such switches, those threaded collars are not very strong once deformed in any way.
Good luck though!
