Don't expect everyone to know this from memory, can you post a schematic. Usually, low valued caps have to do with stability, RF filtering, or similar.The 1073 has 180pF across the mic input TX and 2n2 across the line input TX.
As far as I can tell the only effect of these is to make overshoot/ringing worse.
I suppose Neve had a good reason, but what then?
/Henry
I guess that a better question to ask is if he has measured any ringing or if he is just assuming it rings from looking at the schematic.Are you testing the ringing with the transformer connected to the rest of the circuit ? In my view you should be looking at the ringing on the output transformer with a sensible load connected to it. i.e not just a meter or scope probe.
Yes that's exactly what I've been doing, with a Neve clone preamp and a new transformer that is supposed to be a good substitute for the one used by Neve. My conclusion was that in all cases having these capacitors straight across the capacitor made the ringing significantly worse. So I wonder why NEve put them there - I'm obviously missing something!Those are probably some sort of Zobel networks to tailor the response of the transformer, it doesn't necessarily makes ringing worse. If you have one nearby, you can look on a scope with and without the cap. Transformers have resistance, capacitance, and obviously, inductance, so adding a cap would change the response, not necessarily making it "more ringy".
Years ago, I used to experimentally add capacitors to the secondaries of transformers whilst applying a square wave to the primary. Combinations of capacitors, or capacitors with resistors, obtained in many instances very good results.
Absolutely. Yes that's what I've been doing. There's more detail about how/what I"ve been doing experimentally over in this thread Neve-ish modded GoldenAge-pre73 w.Carnhill inp TX damping results/advice? . I've been largely talking to myself there though I reached my own conclusions in the end, but as it seemed to fly in the face of the Neve design I'm trying to sanity check it!Are you testing the ringing with the transformer connected to the rest of the circuit ? In my view you should be looking at the ringing on the output transformer with a sensible load connected to it. i.e not just a meter or scope probe.
Hi again, yes it's based on measurements (see response to Rob Flinn). I will add some more to my project/experiments thread as I tested the line input similarly and came to the conclusion it also looked a lot better without the 2n2 cap.I guess that a better question to ask is if he has measured any ringing or if he is just assuming it rings from looking at the schematic.
Yes that's what I was doing.I usually determine Zobel network RC values experimentally to give the cleanest square wave response over a reasonable range of source and/or load impedances. This approach works better for me than blindly copying the original circuits.
That was my own starting point, and practical approach - it just seemed so often copied I thought I must be missing something!That’s a part that shouldn’t be copied with different transformers until proven.
That's an interesting comment - the kind of present day experience I was hoping to find out about - thx.Very good iron (term used here as a pseudonym for "Transformers") needs little correction by way of Zobel network.
Lundahl typically requires very little compared to old school, steel laminate xfrmrs.
This is the kind of distinction I'm interested in understanding better! As mentioned in a comment I made somewhere up above (#7), I think of a 'zobel' as a capacitor in series with a resistor as you say, but find it hard to see why you'd have zero ohms of resistance in it, creating what you call a capacitive termination. If the (terminating) capacitor across the TXout was much smaller I could see it might help reduce RF ingress and keep out of the way of the audio band, for example, but the 180p in the [modernised]Neve circuit seem to create ringing at much lower frequencies.Terminology
A zobel network is a R and C in series.
a single C or R across the secondary is capacitive or resistive termination.
Sorry Rob, I just scanned past your comment again and noticed that I misread it previously. I read it as "on the output of the transformer with a sensible load" but in fact you said "on the output transformer..." - in case that wasn't a typo then I should add that yes I did that too. I found that a 600ohm load on the line output transformer killed the majority of spikes and twitches on the leading edges of the square wave test signal, the worse ones still broke through a little, and some funny little distortions of the leading corner occurred in a few cases.Are you testing the ringing with the transformer connected to the rest of the circuit ? In my view you should be looking at the ringing on the output transformer with a sensible load connected to it. i.e not just a meter or scope probe.
“Often copied” is an ongoing problem in electronics, commercial and DIY. Lots of stuff made and sold with little understanding of fundamentals. Always question!That was my own starting point, and practical approach - it just seemed so often copied I thought I must be missing something!
