Echo North
Awesome!
I'm definitely in.
Thanks for all the hard work Sahib and Volker.
Mike
I'm definitely in.
Mike
pricing idea: lowdandeurloo said:looks great. Any pricing or time line ideas yet?
sahib said:I will design a new case for it very soon but there are also so many ready made boxes out there which may turn out cheaper.
TomWaterman said:I'm looking at something that could be well over 175mA.
I did a small run of PCBs for thisTomWaterman said:Did you ever develop some kind of current spec per slot? ...
[silent:arts] said:for the other "API" options:
I will ignore them. I doubt "modern" modules will have all this +4/-2 input output stuff, nor the gain resistor feature. all of this, incl. termination resistors, should be placed directly on the modules. otherwise it is not plug and play.
mhm - the backplane will get some changes, mainly for some cheaper connectors than the Edacs.Biasrocks said:I know this is late in the game, but termination resistors are not a part of any API module I've come across. In fact, termination is provided in the console frame itself. In my home made API rack I've soldered termination resistors directly to the 15 pin connectors, which is obviously not possible with this design.
This is a crucial feature which changes the sound of the modules and should be included on the back plane PCB IMO.
The benefit of having something handwired over a pcb is that if you plug and unplug something too many times, the circuit board traces can break. When its handwired the wire flexes so this will never be a problem. Also this makes repinning a breeze as you just move one wire after another. Not possible on a circuit board.
